BajaRon
Well-known member
I do not enjoy reporting things like this. But maybe it will help someone else. Which is my primary purpose here.
We had a customer come in yesterday with a 2017 F3. She took it to her dealer in late 2022 for the front sprocket (supposed to be permanente) recall fix. She rides a lot and though she would probably be considered an aggressive rider, she is petite and probably doesn't weight 100 lbs. Rides with little to no baggage and takes good care of her Spyder. In short, she is just a very nice lady that loves to ride!
She was on a ride yesterday (it was beautiful weather). Pulling away from a stop, 'It made a terrible noise and wouldn't move at all'. she told us over the phone. Luckily, she was not far from home and she has a friend with a trailer. We had a feeling we already knew what the problem was before she arrived and found the issue quickly (videos below)
https://youtube.com/shorts/8JPg37RDHek?feature=share
https://youtube.com/shorts/iMmbV3cOr1w?feature=share
Yes, sadly, the front sprocket had failed. Even more sadly, when we asked her how the service was done. Essentially, how long did they keep her bike. She told us the dealer said she could wait and take it as soon as the work was done. Which is pretty much what we suspected with this failure.
It could be they did not torque the bolt correctly. But there is also a special Loctite product that is used for this repair. Loctite (and the BRP repair bulletin) states that this product must be allowed to cure, undisturbed, for 24 hours. This was not done and is, most likely, the reason for the failure.
We took both of our recall Spyders to a dealership for this same recall repair. The 1st one they told us we could take right away. We declined sighting BRP's and Loctite's 24 hour cure requirement. The 2nd one we had to redo ourselves because they put the washer/spacer on the wrong side of the pulley. Which was quite obvious because the belt was running hard against the front pulley flange and out of alignment on the rear pulley.
We recommend that owners ALWAYS check work that is done to their ride, if possible. From oil changes to whatever. We recommend this for our work as well. Anyone can make a mistake. The sooner it is discovered, the better for everyone. We've had customers come in with tie rods left loose after an alignment, (which destroyed their new front tires), rear brake pads that were not replaced during a full brake job, over and underfilled oil levels after a service and more. I know it seems ridiculous, and really, it is. The owner shouldn't have to know more about their ride than the dealership. But believe me, it doesn't hurt.
I'm an old guy and I just don't remember it being this bad in the past. Maybe it's just me. But it seems like mechanics generally took more pride in their work in days gone by. This isn't restricted to our Spyders. We have Honda, Harley, you name it customers telling us similar stories about their rides as well.
As for our customer. She called the dealership to tell them about the failure. They told her 'Sorry, you're out of warranty'. In my opinion, this kind of treatment is not warranted. Nor is it good for the dealership or the Spyder brand.
I'm NOT against dealerships! I want them to succeed! I used to promote them. But I got pushback from customers saying it was going to hurt my reputation if I persisted. When dealerships fail, the machine fails. A well managed dealership is good for everyone.
I know there are good dealerships out there. If you have one, I implore you to appreciate them. But at the same time, I suggest there is no reason they shouldn't all be excellent. They certainly charge as though they were.
