Thanks very much to the shelf it will go!:bowdown:
Hi Crisis,
Re: Thanks very much to the shelf it will go!
Just to be sure I know what you are talking about ( I have a GS also ), there two plastic panels under the engine; one on each side if I am correct as to what you are referring to.
Here is where the one on the left goes ( it has been removed in this photo ), just under where you drain the oil reservoir:
And here it is sitting on my garage floor:
I recently did my first oil change ( thanks, Gene ) & had it removed to keep oil from getting all over it.
Are we on the same page?
Jerry Baumchen
Hi Crisis,
Jerry Baumchen
I too have the spyder pops heat mgt system and am about to install their heat shield also. Have you noticed a reduction in the hot leg area with your nstall?Hi Crisis,
Re: spyderpops vent
Yes, I do have their heat mgt system installed.
Jerry Baumchen
I made up my own Alloy Skid Plate. Heaps better, stronger than the "plastic" one
