Front end shake
Mcolabella
I have a 2019 F3 limited, really liking the ride just turned 500 miles on her. I have noticed some shaking or maybe gets a little hanky or loose around 65 just feels weird since this our 1st spyder or even a trike.
is this normal or should I get it looked at
Sounds like the wheels need to be balanced. Or BAd Tires. They been known for shaking.
Take it back and start with a balance.
Was it aligned too?
I am not sure it was brand new, I would hope if was alligbed and tires balanced
Sorry Mcolabella, but the 'factory alignment' is not really great to start with (altho it is MUCH better than it was!) and getting 'good' OE Spec tires that are balanced &/or even able to be balanced is still a bit of a lottery draw (altho they too are MUCH better than they were!!) :banghead:
Even straight out of the factory, and ESPECIALLY if your dealer says they have aligned it & balanced the tires but they aren't recommended by many here for doing a great job on that sorta stuff (& very few dealers are!) then you'll very likely need to find someone (like Squared Away?!) who can do a good alignment on your Spyder, giving it just enough toe-in to stop it wandering &/or darting all over the place; and if you are lucky enough in the lottery draw that is the OE Spec tires, maybe you can get them balanced properly too! :dontknow: For some, that 'proper alignment & wheel balancing' will fix it! But if you do continue to have the problems you describe after a proper alignment & tire balance (and many do!) you are probably not quite so lucky in the lottery draw of getting good tires, so you may have no other option but to get the front tires replaced! :gaah:
If you do need to do that and try going with the OE Spec Kendas again, you are running the same 'lottery draw' risk, and so could end up with crappy &/or un-balanceable tires again; while if you choose to go a/mkt & fit similar (but not necessarily identical) sized tires, you will likely need to take the tires off the Spyder yourself and take them to a tire dealer/fitter to fit your auto tires of choice (btw, the rims ARE auto rims, not motorcycle rims!) hopefully someone who has the 'smaller than most' fittings to properly balance them, because it seems that on BRP's insistence, few Can-Am Dealers will fit anything but the OE Crap tires! :cus:
However, most who do 'go to the dark side' find that just about any properly fitted & balanced auto tire that meets or exceeds the necessary load & speed ratings will resolve the balance & vibration issues that you are currently experiencing; and (run at the right pressure for your load & use) they are also likely to improve the ride & handling of your Spyder beyond your expectations! And often do it cheaper AND last longer too! :ohyea: :thumbup:
tire vibes
:agree: with Peter, about the crappy Kenda's .... you might get lucky and still be able to spin balance .... so far I haven't encountered any shop that doesn't have a small CONE for the machine :clap: .... If the dealer won't help you , remove the wheels/tires and take them to a shop that does auto/trk tires ... see if they balance, if not the dealer should replace under warranty because ....THEY ARE DEFECTIVE ... you didn't cause it ..... any good auto tire will be OK on the Spyder ... however I recommend the Vredestein Quatrac 5, Conti pro contact is another ..... good luck ... Mike :thumbup:
If it is a tire balance issue, tire bounce should be visible to the rider. Prolonged out of balance usually results in cupping, which can be felt by running a hand over the surface of the tread.
We aligned a 2020 RT. Still felt weird. Pulled the wheels off, put them on the balancer. Horrible! Skinned off all the weights, rebalanced the wheel. Fixed it! Both wheels needed to be balanced! So, insist the dealer does that. While that is done at the factory, this experience we had tells me that they might just miss it. So, if the dealer does not ride it, it could slip by.
My 2016 rode like a horse when I bought it with 2,500 miles. Jack up a front tire and spin it. Mine have Flat Spots. If yours have flat spots forget about balancing them. I have two new tires but haven't found time to get them mounted... YET.
