frame upgrade? 998 change in 2014? looking to buy
AZRooster
I have tried finding this information, on this website, google, other sources to no avail. I saw reference once of a frame upgrade for the RT in 2015. Anyone know if this is true, and if so what it fixed?
another question is, when the RT went to a 1330 (2014), did anything change with the ST model line? I read the engine went from low compression to high compression, changing the need from regular gas to premium, with a reduction of 6 HP. Were there other issues changed/fixed?
Which platform from 2014 and newer, is more reliable?
If the ST did not go thru any real changes/correct any flaws, is it just as good to buy say a 2010 as a 2014?
reason why i ask, is i am trying to decide between a 14 RTL and a 15 STL.
appreciate any clarification that can be given. Always loved the spyders.
First, you are dealing with two different Spyders with different riding positions, different engine performance characteristics and different use purposes. One is a more sporty bike, the other designed for loaded touring. Therefore, you should extensively test ride both Spyders and decide which is most comfortable and most closely meets what you want to do with the roadster.
Second, frame modifications to the ST would not be noticeable to you without knowing exactly what was changed and why and you would have to test ride both vehicles to see which better suited your riding style -- if you could tell at all.
Third, combining one and two above with the fact that the ST is no longer produced it's fairly easy to come up with the reason why; the 1330 ACE engine is state of the art while the 998 V-Twin is past its prime in BRP's money making opinion.
first, i realize they are two different riding positions. i have researched both of them, and the f3 (which i dont like the riding position). i ride both sport and tour 2 wheels. i never asked a question about the riding position, but thanks for giving information that had nothing to do with the first post.
second, i asked about the frame modifications to see if there was an inherent flaw discovered which warranted a frame modification, and if so why, and what year would be the better frame for reliability. when they upgraded my king quad frame, i never noticed a problem with the old one. they would just crack under certain extreme conditions in certain spots. knowing makes it easier to identify when purchasing. such a long answer that didnt have anything to do with actually answering the question. btw, you in politics?
third, if you read the original post thoroughly and had decent retentive skills, you would notice the ST that I am looking at it is a 15. I am aware they do not produce that model anymore. again, not the original question. just because they stop using one engine that has been in service for 10 years or so and gone to another, doesnt mean the new engine is better (although i would hope so). in this case, it may be, but it doesnt mean the old one had problems. remember the 7.3 ford diesel and how much "better" the state of the art replacement was? technically, since they changed the compression of the 998, upgrading the engine, didnt BRP invest a little more R&D in it, possibly making it a better engine?
i would say thanks for taking the time to respond to my questions, but then again you really didnt answer any of them, so i wont.
#1. - the ST always had the V-twin engine and the same original frame - all years .... The frame change actually came in 2013 ....however BRP couldn't get enough 1330 engines, so they shoe-horned the V-twin back in ( which caused over=heationg problems which required a SCOOP kit to remedy ) .... The 13 + frames allowed for the shocks to be put more up-right so they would respend better .... there have been a few SHOCK / SPRING changes .... to numerous to mention ..... Mike :thumbup:
first, i realize they are two different riding positions. i have researched both of them, and the f3 (which i dont like the riding position). i ride both sport and tour 2 wheels. ......
second, (*1) i asked about the frame modifications to see if there was an inherent flaw discovered which warranted a frame modification, and if so why, and what year would be the better frame for reliability. when they upgraded my king quad frame, i never noticed a problem with the old one. they would just crack under certain extreme conditions in certain spots. knowing makes it easier to identify when purchasing. .....
third, ...... (*2) the ST that I am looking at it is a 15. I am aware they do not produce that model anymore. ...... just because they stop using one engine that has been in service for 10 years or so and gone to another, doesnt mean the new engine is better (although i would hope so). in this case, it may be, but it doesnt mean the old one had problems. remember the 7.3 ford diesel and how much "better" the state of the art replacement was? technically, since they changed the compression of the 998, upgrading the engine, didnt BRP invest a little more R&D in it, possibly making it a better engine?
i would say thanks for taking the time to respond to my questions, ......
AZ, seeing that you're a new poster here, I'm giving you a little leeway & simply removing the unnecessary comments from your post in the quote above (see these ...... bits) but I've left the original post as is - as a Moderator here I'm giving you a heads up that the sorta stuff removed is not acceptable here! You really should check out the Forum Rules (click on the bright green Forum Rules at the top of each page ;) )
Furthermore, and I'm putting this out there for everyone, not just you AZ - a reminder that you really can't tell from the written word exactly what level of offence any other poster may be attempting to convey, but immediately jumping to the conclusion that they were aiming for the highest level says a lot more about you & 'your offendability' than it does about them, especially when it appears to everyone else that they were simply trying to help by providing info you may not have been aware of! :lecturef_smilie:
_________________________________________________________________________________________________________________________________
OK, that bit of 'housekeeping' over, re the bolded bit at (*1), there were no significant issues with the frame prior to 2013, the major reason for the 'across the board/entire model range' frame upgrade/mods was simply to make room to accommodate the dimensionally larger & heavier 1330 Triple Cylinder motor & improve the brakes (Brembo), ride, & handling a little to suit along the way. :ohyea: . All the 2013 RT's & the 2013 & on RSS/ST's that retained the V-Twin motor benefited as a result; and so, once the heat issues were resolved, they arguably became the pinnacle of the V-Twin versions of those model Spyder's available, what with better brakes, ride, handling, AND they still had the revvier, peppier, more exciting engine!! :yes:
(*2) Re the engine, if you take the time to go looking back thru the early threads here, you'll see that many people, particularly in North America, simply weren't used to a high revving motor that thrived on revs, used a little bit of oil between scheduled changes as a result, & didn't deliver a heap of power/torque below about 4,000 rpm - something that caused a lot of rider angst, some difficulties in learning how to get the best from the motor, and even some failures due to 'mis-treating' the motor/clutch/gearbox by never revving it hard enough & letting it lug around well below the engine's power/torque band & the 'lock-up' revs of the SE clutch :rolleyes: .... and for once, BRP listened! :shocked: (but they STILL haven't listened about those bloody poor excuses for black round things to keep the metal bits off the road they have the audacity to call OE tires! :cus: ) Anyhow, back to the motor - hence the 2014 move in the continuing models away from the revvier, peppier, more exciting to ride V-Twin engined machines to the lazier but lower revving 1330 Triple that undeniably has scads of torque from down low in the rev range, but never really gets any better than that.... :sour:
Now you juuust might detect a little of my bias showing in those last couple of para's, but I freely admit that I PREFER the revvier, peppier, & more exciting to ride V-Twin powered RT that I ride over any of the 1330 Triple models I've test ridden since! So far, there hasn't been a 1330 Triple released that's done anything much for me; I reckon the Triple engine is a lazy motor, and even if one of the Tuning Guru's waves their magic wand over the ECU & matches that to some intake & exhaust upgrades to suit, it's STILL a lazy motor in a heavy machine :banghead: . The 1330 Triple is a motor that comes nowhere near delivering the adrenalin &/or buzz of pure enjoyment that I get just about every time I ride a V-Twin engined Spyder :ohyea: So if you too want an exciting ride, you might want to keep that in mind, & maybe do those test rides in order to make up your own mind about that?! :dontknow:
Enjoy, & good luck with your Spyder Hunt! :cheers:
A big challenge you're facing is that many owners who would know some of this info would have been active back in the 2013 to 2015 time frame but are no longer active here. That knowledge is lost. But if you Google "specifications 2013 spyder st" and the same for 2015 you'll dredge up old spec sheets. Comparing them may give you some of the info you're looking for. I didn't make note if the torque and HP specs were different or not.
thanks for the info, thats why I asked on a forum instead of FB, figured it would cut all the crap and get straight to good information.
the STL was a wasted trip. the car dealer that bought it at the auction didnt know how to start it. the body panel that fell off because it was missing connectors and the loud "CLUNK" that shook the bike when i put it in first gear screamed run from this sale.
Peter Aawen, I take it you prefer the 998 over the 1330 to power an RT? I was avoiding the older ones due to the smaller engine. Looks like I will widen my search, again thanks for the info.
Unless the clunk was REALLY, REALLY, frighteningly LOUD, it is normal. All Spyders clunk into first gear from neutral, kind of like Harleys!
AND they'll clunk into Reverse!! :shocked:
But it's simply the nature of the beast - selecting any gear from Neutral will do it, simply because the engine is already turning all the gears but not the output shaft - not yet, anyway! :p . But once you've selected 1st In the constant mesh box & engaged the output shaft, it'll all be spinning from there on in & it shouldn't clunk (too loudly anyway) until the next time you select a moving gear from Neutral! ;) . Starting from Cold & selecting 1st or Reverse is usually worse for the clunk, but that can be reduced by warming it up a bit longer; and besides, the clunk isn't going to hurt anything, it's common in some degree to all similar types of gearbox/drive arrangements, and the components have been designed to handle it! In fact, about 2013 or so they were upgraded a little, just to be sure to be sure! :ohyea:
So if you're planning on Spyder Ryding, expect & get used to that clunk! :thumbup:
Ps: YES, I much prefer the V-Twin engined Spyders to those powered by that lazy Triple, even if they might have more torque at lower revs, they just don't give the same rush - and at best they sound like a half full can of gravel rolling down the road! :barf:
Buying a Plane at Boat dealership rarely works out well either .... JMHO .... Mike :thumbup:
AZ, I have found that if I let the engine run a little so that idle goes down from the 1500-1600 range at start up to 1300-1400, the clunk is greatly reduced,but it will still be there. As Peter said it is inherant in this motor. It does not cause a maintenence problem or a reliability issue ,just an assault on the ears.
The frame changes were to accomadate the across the frame mounted 3 cylinder,heavier 1330 as opposed to the inline mounted VTwin. Good luck in your search
As already mentioned, The first frame change came in 2013. The only change to the 2nd Gen frame (that I know of), is the addition of 2 stiffening bolts in the Sway Bar Channel. Something that anyone could easily do with a small drill and parts from BRP. So, essentially, the frame from 2013-2019 are virtually the same.
I don't know that a frame generation would be a major factor in a decision on which Spyder I'd want. I think fit for my needs, price and condition would be much more important. But that's just me.
2008-2012 - 1st Generation Frame
2013-2015 - 2nd Generation Frame (Major Changes)
2016-2019 - 3rd Generation Frame (Only change I know of is the 2 stiffener bolts to the Sway Bar Channel) (See Picture)
2020-2022 - 4th Generation Frame (Major Changes)
