I'm about to install the Fox shocks to my 2013 ST-limited. In the instructions it basically tells you to install the shocks and then for the adjustment it says something to the affect of "refer to the operators manual". Well i know that theres nothing in my manual. Looking at the operators manual for 2013 Spyder RS, it lists that the distance between the shock bolts with rider(s) and cargo on the bike should be 16 7/8 inches. So I thought okay..this might be it. But then I remembered that the 2014 Spyder ST-S bikes supposedly CAME with the fox shocks but the 2014 ST operators manual says NOTHING about them. So I looked in the 2014 RS operators manual and for some reason, for 2014 the distance between the bolts of the shock with rider(s) and cargo dropped to 16 1/2 inches....argh. Should i go with the 2013 numbers? the 2014 numbers? Anyone have a 2014 Spyder ST-S with the fox shocks? Did you do any adjusting?
I guess I will install the shocks and then measure...this overthinking may be for nought. BTW, have a Baja Ron sway bar on the way too. Thanks
