Just curious about this question as the bags do not place any stress on any of the fenders...
Isn't he talking about the fender brackets? It seems that any weight back there, from bags, a passenger, or yourself will stress the brackets anytime you hit a bump.
The problem is actual contact with aftermarket luggage rack parts. This will occur if the rear shock is adjusted too soft, or if you hit a pothole. And yes, extra weight, of say, a passenger or luggage, will make it worse. Check the photo to see some contact marks. Later, several other indications showed up on both the fender and the brackets. If this continues, the fender will self-destruct.Since the swingarm is completely independent of the main frame I can't see how additional weight on the rear is going to put any stress on the fender brackets.
Do you remember that post where it mentioned there was a bulletin dealing with the brackets breaking on the earlier GS's? The bulletin mentioned a specific torque sequence to follow; but, the actual torque value did not change. Supposedly, if you followed the new torque sequence, there would be less stress on the brackets when going over bumps, rough roads, etc. At least that's what I understood my dealer was telling me after he looked up the bulletin.
If you have the I7 rack with the GIVI bags and you develope the cracks, BRP & your dealer will tell you it is the fault of the non-OEM
rack hitting the rear fender and you will pay for replacement yourself rather than have them replaced under warranty. Ask me how I know.
Doc went thru white a few of them, but I think his TURBO caused them to crack.
Apparently his turbo caused a lot more than just a fender crack! :shocked:
Ok, I understand physical contact and that extra weight could be a factor if bottoming the suspension causes additional contact. I read that post as simply a weight factor alone.
But it is my understanding that people are losing fender brackets with no contact issues.
