Foglight question
bwbarnes
I recently installed BRP foglights on my wife Spyder and they are working great!:2thumbs: My question is are they supposed to shut off when the highbeams are on? These are not shutting off and in Virginia the state inspection has this stupid rule that foglights must shut off when on high beam. Both of our cars' factory fogs do shut off and I expected the factory BRP fog to do so also.
Thanks,
Bruce
Yorktown,VA
I had the dealer install my fog lights. They do not turn off when head lights are on high beam. Evidently they are not tied in with the head lights.
You are, indeed, out of luck. The Spyder low/high beams aren't technically even switched. Low beams merely lower a shutter over the top part of the projector lens. You will have to switch manually, or take your chances with the law. I do believe you could easily rig a relay to do this automatically if you wanted to, however.
-Scotty
