Fog lights not working - checked fuses & relays, what do I check next?
DavidSpyder
2014, RT-S
Fog lights not coming on, I always leave them in the on position, but...
Checked fuses and relays and didn't find anything out of sorts. What do I check next, and how often do the switches fail?
David
If you always leave them on, then the switch should be fine; could be the bulbs or a ground issue at the lights.
Checked fuses and relays how? Did you just check by looking at them or seeing if they were in the right position?
Did you use a multi-meter to actually see if there was power going through the wires, or just assume there was no power because the lights were not on? You have to know which wires have power in them and if it is the correct amount of power to really test the system. Then, when you get to the point where there is power on one side of a component, but that power doesn't come out the other side of it, you have located a problem.
