Fog light recommendations - 2016 F3T
crabbylady66
Good evening! I am looking for LED fog light recommendations on our 2016 F3T. Thanks in advance.
~Laurie
~Laurie
I, too, have to say Lamonsters Garage.
If you're going to get his LED fog lights, do yourself a favor and change out your headlights to LED's too. You'll kick yourself in the butt if you don't.
Here's our fog light kit
http://www.lamonstergarage.com/lamonster-f3-led-fog-light-kit/
and here's our head light kit
http://www.lamonstergarage.com/h4-led-headlight-for-spyder-f3-st/
:agree::agree: Have both the LED foglights and the LED headlights from Lamonster! Awesome!
Combination
If you are going with the Lamonster lights, add the Fog Rings and the BRP heat shields. The Rings add a lot of light and visual effect and the heat shields give a nice finished appearance for an additional twenty bucks. The combination of the fog lights and rings pretty much fill the holes in the heat shields. You might as well do it all at the same time since you will have the tupperware off anyway. I left the factory headlights in place, since the two colors of light seem to be more visible than four lights of the same color during the day. I may change out the headlights when one burns out.
Here is another option: Tricled LED Halo Fog Lights. Dual function: White LED running lights and amber turn signals. Had these installed at Red Rock Rally recently and very pleased.
Heat shields
Where re would we find the heat shields? Do they come in the kit with led fog lights?
Heat Shields
Just order them from your Spyder dealer, they are less than ten bucks each including tax in California. They replace the blanks for the fog light installation. Some people have cut out the blanks, but for twenty bucks I liked the factory finish better. (I tried the other route using a hole saw, but wasn't happy with the holes and sanpped one of the blanks in half when the hole saw grabbed).
Will the heat shields work with Lamaonts LED fog lights?
Also, I just looked in the 2016 accessories catalog and could not find the heat shields. Any idea of the part number?
Heat shields
I have both the Lamonster Fog Lights and Fog Rings and together they just about perfectly fill the holes in the heat shields. The Fog Lights alone will leave about a 3/8s inch gap in the holes of the heat shields. I looked up the parts number for the heat shields for you, in the 2016 model, they are under Body and Accessories-general. They are item 119, the parts numbers are 705008995 (Left Hand) and 705008996 (Right Hand) They are easier to find in the 2015 drawing, since they are listed under faring parts. The parts number is the same for 2015 and 2016 models. Good luck with your mods.
Here some photos
Lights
Pics don't do then justic, just installed the fog lights with halo ring and headlights. They are blinding bright. Lamonster shipped fast and had them in 3 day. Very happy with there products.
Lamonster Garage is the best place for all of your spyder needs.
Bought Lamonster LED fog light and Amber blinking turn signal rings that mount on the fog light bezels. and LED headlight kit and Jacob installed them for me while I was at Lamonster Garage,
Awesome product and the amount of light produced is way better than stock headlights and fog light kit.
