J48cruiser
I am setting up the FOBO and the correct tire pressure for a Spyder RT limited with stock tires
My Spyder is a 2015
My Spyder is a 2015
All tire pressures you see and will get here are suggestions and good for those recommending them. You and you alone should find the best pressure for your ryde. There are so many factors that play into getting the best one. Start with the factory recommended pressure (not the one on car tires) and adjust from there. They are cute gagets and make many feel good but are just gas gauges for your tires. Unless they have a compressor attached to adjust the pressure you do the same checking your pressure before your rydes and at altitude/weather changes, if prolonged. jmo one more thing that can keep your eyes off the road and can fail and cause problems....:thumbup:
Absolutely agree! :thumbup:All tire pressures you see and will get here are suggestions and good for those recommending them. You and you alone should find the best pressure for your ryde. There are so many factors that play into getting the best one. Start with the factory recommended pressure (not the one on car tires) and adjust from there
Absolutely disagree! :lecturef_smilie:...They are cute gadgets and make many feel good but are just gas gauges for your tires. Unless they have a compressor attached to adjust the pressure you do the same checking your pressure before your rydes and at altitude/weather changes, if prolonged. jmo one more thing that can keep your eyes off the road and can fail and cause problems....
Like Ann says, the FOBO is SO much easier than crawling around on the ground to check your pressures. For me, it's literally the difference between checking pressures and NOT checking pressures before each ride. And they are very accurate, do not leak, easy to change the batteries when necessary, and I never have to look at it after the beginning of each ride. If it needs to communicate with me about a pending problem, it will do so via a tone to my headset (via my phone).
Don't mean to be in "Soap Box Mode" here.It's just that I consider the FOBO TMPS to be one of the best farkles on the bike. Makes riding SO much more enjoyable to not have to wonder about tire pressure - especially when that rear tire is so dang-awful hard to check on an RT.![]()
Gene, I have to disagree. First there is no reason to take your eyes off the road with a FOBO, if you had a sudden loss of tire pressure and you are looking at your phone or have audio from your phone you would get a warning tone. That could save you problems if you get off the road before you lose all the pressure. Also, I check tire pressure on every Spyder that we align, and we have done somewhere around 800, the number of Spyders that have incorrect tire pressure is staggering. It isn't unusual for me to find tires that are 5 or more pounds low - even in the front. Let 5# out of your front tires and it will handle like a semi truck. So many riders fail to check tire pressure before each ride but if they had FOBO they only need to open the phone app.
I'm sitting on the couch and I know that my tires are slightly low but not low enough that I need to get on the ground and add air. Pushing a few buttons on the phone sure is a lot easier than getting down on the ground.
Yes plu when I come out of the diner and someone says looks like your tire is low just clck and see nope good to go.Gene, I have to join Ann and Rob in disagreeing with you. A smart and safe rider always knows what the air pressure is prior to a ride. So how do we do it? We crawl around the garage floor on our hands and knees with a gauge checking each tire. The FOBO system is a life saver! Now I can just look on my phone while sipping my morning coffee and know if I need to air them up before departing. If I'm on a trip somewhere and get an alert, I can simply pull into a gas station or tire shop and air up.
Pam
I bought and installed Fobo on my RT-S, but I didn't really think of it as a farkle, just common sense.
Those are what I always used on my Honda ST. I've had no issues with the Fobo product.What's a good product? I used to use tire valve caps that read green if it was the assigned PSI and red if it was low. Until I had one that read "green" for a totally flat tire.:yikes:
~Sandee~
With all this said--just remember getting up and down on the garage floor may be the only exercise some on here get. And your gonna take that away? :yikes:
Jack
