Dochatley
I am having a problem getting the recommended pressure to stay set. When I go into the settings and go to profile and hit edit bike profile I set the front tires to 20psi and the rear to 30psi. Then I go through the process of recalibrating each wheel as it says and all is good. Then I come back later and the rear tire and front show 19.8 as the recommended setting and the alert is showing rear tire problems since it is at 30psi. I have tried releasing all sensors, reinstalling the system and same results. The recommended psi for all 3 tires goes to 19.8psi no matter what I put in initially. It stays for a while the when I leave range and return its at 19.8 recommended. I have checked the instructions over and over. What am I doing wrong? Any help appreciated.
Thanks.
Thanks.
