fobo bike sensors will not sync
bikerjays
I had an issue with 2 Fobo bike sensors. After reading the manual, I disabled both sensors figuring I could re-enable them when I figured out the problem. After checking out the pressure and installing new batteries, I attempted to resync them. No Luck. Any ideas on how to get them back operational?
I also just now have one that will not sync with the app. It reads at 4 pounds. I have disabled and re-enabled. I have removed the battery and let it sit for a while and reinstalled the battery. I have tried a new battery.
I will watch this thread to see if you have a solution. In the meantime I will write Fobo. I will report back with what I find.
ba
Most likely a firmware issue. Especially if using an Android device. fYI, there is no option with the Android version of the app to update the firmware! Ask me how I know! Anyway, you will need an Apple product to do the firmware update. Anything that you can get the app installed on will work. It is a bit of a PITA but it solved the issue for me.
The firmware failed with undetectable sensor.
I sent a message to FOBO.
ba
