FOBO and Shamrock Wheels
IMG_0354.jpgIMG_0320.JPGNot sure how recessed the stem hole is, but get a chrome straight 1" bolt in stem. Check what you have now and likely it is short and the recess is causing you to interfere with the full installation of the FOBO sensor. Do not put another rubber mounted stem in to replace it while you are at a point that an all metal one is best. Check your local auto parts store as most likely they will have this stem. Hole is .453 dia
Buckskin
Is there any way to add the FOBO Tire Preasure Monitors System to the Shamrock Wheels that come standard on the F3L?
Thanks
