floorboards
bmccaffrey
View attachment 92239View attachment 92238
Here you go folks this my design. I tried to makit as simple as possible. Tube welded on to slide over foot peg
Small 1inch angle to slide over brace for footpeg to hold down pressure. There Is holes drilled on bottom side of tube with nuts welded on for bolts to secure board.
I do have access to cnc plasma and brake. Thats why the web Is there. For the do it yourself you can make it
square. If you dont have a bender pieces can be made separate.
Yellow spyders I made have a stud welded on back and bolt on. You wouldn't have to put these on . I only did It to make it more attrative. Will put it on dyi with more instructions. Works well happy with the way it came out. Minda i designed around the rs peg. Dont know about st &rt pegs:yes::yes::clap::thumbup:
