PatriotRider
I want to add a switch and flasher to my spyderpops bump skid that came with leading edge led's
I lead funeral escorts for the local Patriot Guard missions and have always had white led's that blink or strobe. I think a flashing bump skid would add visibility during processions.
Anyone have any thoughts or comments about what I need to do. I have the flasher setup for my hyperwhites, but the (separate) flasher is only working two pods of 16 led's each. It's spec might be for up to 6 pods so 96 led's. I could try wiring that in the circuit, but it seems there's lots more led's on the bump skid.
Any specific component you can point me at would be appreciated. I'd wire in a 2 throw switch so it's either solid on for normal use, or flashing for processions.
thanx
we always run our emergency flashers for such events. good news is I have the fender tri-led kits to be wired into the turn signals.
I'll then be thinking of what I want to do with the rear. It would be some kind of white led's that flash.
thanx
