Flamingobabe
Orange monster
If I remember correctly you were going to pick up your roadster yesterday from the dealer and I was just wondering if they were able to correct any of the issues you had it in the shop for?
I did read on FB where she picked it up and had a good 400 mile trip home. But there was no immediate elaboration on the plethora of problems she was having. Except she did make mention of bad exhaust gaskets that might be a reason for the mucho heat problems with some of the 2013 Roadsters.
Carl
I picked my Spyder up on Monday....boy was it a GREAT ride home....took I-30 East to Hwy 19 South to Hwy 190 East to I-59 south...Louis Powersports did me well...I appreciate their time and work ...especially the tech Waco who found an exhaust leak....seems the gasket burned down to the copper...is it a faulty gasket....poor production of gaskets or too much heat from exhaust...the repaired exhaust leak reduced the amount of heat as I rode home in 86 - 95 degrees ......gasket 1 resize.jpghope everyone has their exhaust checked for faulty gasket......after a couple hundred miles...idle is 1000-2000rpm's...either wants to stall or surge forward...thanks for asking
WWWWWWHHHHAAATTTT? You came within 20 miles of Tyler and didn't come over or call or txt or.....
;) I know you were itchin to get home :) I would have been....
Phil, Tyler TX- from my iPad 7.5 using Tapatalk HD
Tell you what Phil...I was having the time of my life...shifting between 7000-8000...maybe more...but we came to a 4-way stop.. Tyler....it had an arrow pointing east ,,,I thought of you but I was on a mission...now that I have the bike back home maybe it's time to plan a Saturday or sunday ride to meet-in-the-middle
DEAL!!!
Sent from my iPhone7 using Tapatalk
Yeah..!!
I switched to the honda gaskets are much better. I do not have the heat nor were my gaskets gone but did not want them to go while driving around. Ours is an RS and not sure the ST has the same gasket. If it does I would recommend using them..but so glad she's back on the road...!! :clap:
I have a Goldwing 1800 gasket in the shop... I used them on the RS, and I used to have an 1800... Hey... I NEVER throw anything away.... doesn't mean I can find it when I need it....:ohyea:... I will check the sizing....... but it looks to be a different size.... I do know where the gasket is...:yes:
Louis Powersports and Waco are the best.:clap: I bought my RT from them and have had all my service work done there.
Louis powersports
I live in calif. and have found the best pricing to be at greenville,Tx. @ louis prowersport. i have even looked at air fare and rental car. I would like to say that is the Best spyder forum I've found with the best info and kindness to newbees. thanks Ruth:clap:
For the RS the Honda part number is 18392-mam-000 Don't know about ST
The Honda gaskets won't fit on the exhause systems for the 991 series engines...
Char,
Glad to hear that you got your hair back out in the wind!! :2thumbs: :yes::ohyea::yes:
I picked my Spyder up on Monday....boy was it a GREAT ride home....took I-30 East to Hwy 19 South to Hwy 190 East to I-59 south...Louis Powersports did me well...I appreciate their time and work ...especially the tech Waco who found an exhaust leak....seems the gasket burned down to the copper...is it a faulty gasket....poor production of gaskets or too much heat from exhaust...the repaired exhaust leak reduced the amount of heat as I rode home in 86 - 95 degrees ......View attachment 76987hope everyone has their exhaust checked for faulty gasket......after a couple hundred miles...idle is 1000-2000rpm's...either wants to stall or surge forward...thanks for asking
So FB, did they replace the gasket with OEM or with the Honda GW replacement as originaly asked?
The gasket was replaced with OEM....Mark is going to check if the Goldwing gasket is the same size.....but the heat is better.....
