Well my rear pads started to really squeal bad at stops now and again (usually at the most embarrassing time), along with slight chirping sounds from the front pads. Sick of hearing that horrible noise and from reading others posts I attempted to remedy the situation. Well I didn't have CRC brake squeak stop GOO available at home so I decided to improvise. I decided to use black electrical tape(Regular found at True Value) on the back of the Generation 1 rear brake pads. Nothing else was done, didn't clean the rotor, didn't spring the pads apart, didn't adjust anything, except lube the slides and apply a single layer of black ELECTRICAL TAPE. I have driven over 100 miles so far not ONE PEEP FROM THAT REAR BRAKE PAD SO FAR on two different days. I will keep everyone posted on my experiment. I will do my front pads later to see if they will benefit from my .79 retrofit.:2thumbs:
