First test ride. Not at all what I expected.
JohnnyK
First I come from riding on two wheels. Second, I read the whole Do's and Don'ts thread which was a big help on the test ride. My first thought as I pulled out onto the road was I am either going to run off the side or over the center line. That first left turn on to the road was like "why the hell is this thing trying to go right? I want to go left!". Being used to counter steer really threw me. For the first few hundred feet down the road I sure I looked like a drunk driver. Then I remembered the thread and relaxed my grip. This was a semi automatic so at the first stop light I had this feeling of "where the hell are my controls?" No front brake, no clutch level, no shift lever. Two things I should have done. First sit on the bike and visualize starting and going up through the gears. Braking with just one foot and no hands. Second, I should have done some slow driving around the lot before going out on the road which was two lanes each way separated by a double yellow. When I got back to the lot and relayed my feelings about the ride he said he usually has people take it around t he lot first but since I was an experienced rider he just let me go. I told him everyone should go around the lot first. Especially bike riders.
I thought I would feel more comfortable with my wife one a Spyder rather than her bike. She just doesn't get enough seat time to get really good at the slow speed stuff and tends to drop the bike occasionally. Five minutes in to this ride I was convinced that she would run this off the road or over the center line and kill herself.
So, how many miles does it take to get real comfortable with the Spyder steering and finger paddle shifter? How long before it becomes second nature?
The steering just seems so sensitive I would be afraid to make a quick correction if needed. I can see why the heavier sway bar is a favored update. This bike just had an alignment at the dealer. It was a used 2010 or 2011 silver RS.
John
TEE HEE HEE....
TEE HEE HEE......
YOU TOO HUH.....?
me 2.... my 1st ride was so 'strange'.... but after 40,000 miles, i would NEVER go back to 2 wheels....
enjoy, and have fun....
Dan P
Easley, SC
SYPD3R
First rule of ryding a Spyder, Do Not Take A Strangle Hold On The Handlebars! Relax, correct GENTLY, don't panic. If you've ever ridden an ATV, it's a lot like that on steroids. Get some markers, cones, whatever, find a mostly vacant parking lot, lay out a course, and ryde thru it. Lean into the curves, you have to, the Spyder won't. It can take 200 to 1000 miles to get really comfortable on a Spyder, but it's worth it!
john
It took me about 500 miles. The first hundred scared the s*it out of me. I was taking curves posted 45 mph at 35 mph. Now it's second nature...I just ride it without giving it a thought.
Relax..!!
somewhere about 300 miles and you will be very comfortable. The steering adjusts to the need the faster you go the heavier it gets. You do have a unlearning period that may un- nerve you. You can get the sm model and get the shift and clutch lever back though most female ryders like the se model. Give yourself some time you will thank yourself...:thumbup:
Welcome and congrats on the switch , jumping on a spyder from 2 wheels is a very tough transition. I found a 2 wheeler is your main back ground, 300 to 500 miles is a safe. Some do take longer. Think you may wanna go to a nice big open parking lot or around your neighborhood and just do little cruising around may help, get the feel for how it feels on turns at a lower speeds first then move to higher speeds. Don't be afraid to move around the seat and lean with the turn.
Same for me, 500 miles and you should be comfortable even on really curvy roads.
The Spyder is for my wife but I'm sure I will ride it too. I'm going to stick mainly to two wheels myself. I'm going to try and get her out on a couple of hour test ride. The salesmen said we could take it for a few hours. My wife says she would rather have the manual shift but I might like it better if she got the semi-auto. Then stalling on a steep hill wouldn't ever be an issue. Any idea which transmission there is more demand for?
The other funny thing is that there wasn't much of a price difference between the used semi-auto one and a new 2014 manual shift.
if you stall on a hill with the semi auto and don't put on the brake you will roll backwards and in my case , grabbing for the hand brake that wasn't there..:yikes:
they all have their features
I've had my ST for a few weeks now, and feel very comfortable on it for the most part. The only issue I have is how this motor likes high revs. Keep wanting to shift. :dontknow:
At 600 miles I am starting to take 45 MPH curves up to 40MPH now. Biggest problem I have now is the leaning makes my hip hurt. Still more practice to come!
My first Spyder was an RS SM5 that I purchased 2 years ago and I had little motorcycle experience but had no problem with the manual transmission. I spent a lot of time on residential streets and rural roads following hubby, to learn the ins and outs of my Spyder. 17k miles later and after BRP came out with the inline triple motor on the new '14 RT's and wonderful heat management, I upgraded because I loved to take long trips and wanted more comfort. My hubby talked me into the SE6 but that SM6 is really, really sweet and so smooth.
JMHO, but if a brand new RT with the all new engine and technology , is in the same price range as an older model with old tech, I'd definitely be eyeing that '14. It's so worth it.....��. And the SE model is the preferred transmission.
I hope you didn't relay your feelings of uneasiness to your wife. It sounds like she is the perfect candidate for a Spyder and she will love it for what it is. A safe way for her to keep in the wind without the worry of dropping a two wheeler. I had very little two wheel experience and it had been 15 years since I had ridden two when I started riding the Spyder. My husband hated the Spyder for the same reasons you are having trouble with it and that worried me that if he didn't like it how could I? I love it and with nearly 100,000 Spyder miles I wouldn't give it up for anything.
Let her take one for a test ride and see how she likes it. She's the one who matters in this. Also, tell her to check out Girls on Spyders on Facebook.
My wife is adjusting very easily to the Spyder (she is an excellant motorcycle rider)
As far as a death grip -- after reading a number of posts on here about wind and 2 wheels or 3 wheels -- I would have to say -- a death grip is not good on any vehicle -- just relax and the machine do its thing
ive had 55 motorcycles and it took me 600 miles to get used to my spyder,i dtill have three bikes now as you can see so send us a pick as soon as you get your spyder you will learn to love it.:2thumbs:
:welcome: and I'm glad you survive the unfamiliar :ani29:.
Take your time and you'll get bitten by your :ani29: before you know it.
On the owners manual there's a guide line to practice riding and it's
recommended on empty parking lot. Enjoy and ride safe.
:welcome: Most people report 250 - 500 miles of learning curve before they are comfortable with the :ani29:. I took about 1500 miles--but am a slow learner I guess. :roflblack:
A few extra minutes in the parking lot is a good idea as well as 50 or so miles on lesser traveled roads if possible.
Glad you made it through the test ryde okay. Like SpyderAnn said, don't give the missus any ideas. She might surprise you. My spouse had it figured out in less than 100 miles back in 2009.
Freak
I hate to be a braggart but I knew exactly how a spyder was going to handle. VERY DIFFERENTLY. The first one I saw on the road I said, what is that freak of nature? I've gotta have one!!!
Parking lot first, 2 lane, one in each direction for a while. Then the best riding experience in the world for most of us. Good luck and have fun.
Oldmanzues
