First Ride Home on 2016 RT Special Scared the Scrap out of me - Handling Help
airtire
Just picked up my Black Beauty today from Bert's in Los Angeles. I test rode the Spyder a few weeks back on main streets (no freeway), getting up to 60 and everything felt great.
Going home today on the freeway the Spyder feels very sensitive over 60 and every lane change felt like it was grabbing and I get a scary type of sway when I am going fast.
We do have grooves in the pavement here, so I wonder if this has anything to do with it. Also, high speed sweeper on ramps, heading in to it about 70 and then hitting the ramp it feels pretty unstable.
Perhaps tire pressure or what do you folks think? If it is a "rookie mistake" let me know. I have been riding conventional motorcycles for 35 years.
Thanks!
Congratulations on that good looking ride. I just got my 'Special' a month or so ago and yes coming off a traditional two wheeler is STRANGE!
First thing everyone here will tell you is relax and loosen your grip! I rode Goldwings forever and was used to the lean and manual force at low speeds... that's all gone here. Put a few more miles on and relax. Get used to the bike not leaning like a two wheeler. I just passed 1600 miles on mine and now beginning to feel 'normal' in a higher speed curve.
I'm too new to really know... but I do know... don't give in too early. You will love the ride. And is u have a co-rider... they will love the sure footedness of the spyder. Enjoy that new toy and put some miles on it!!!!
This is a normal response, especially if you are a two wheel rider.
I picked up my wife's ST-S and rode home 190 miles. It was a bit frightening at first. I have almost 500K miles on two wheels, but the advice here helped a lot.
Light hands on the grips. Let the bike move under you. Lean harder than you think you need to. Push the grips instead of pulling. Look here for full details: http://www.spyderlovers.com/forums/...t-Do-s-and-Do-Nots-quot-for-new-Spyder-owners
I have about 500 miles on it now, and it is great. My wife never had an issue, but never rode two wheels either.
Check your tire pressure
Check your tire pressure, mine were 9 and 10 lbs low when I picked up my RT. It handled much better after I corrected the pressure.
definite learning curve here. Your RT has fairly well "boosted" power steering, which is said to be "speed sensistive". but
ain't so much. Any kind of energy or input from too tight a grip, gets amplified out at the front wheels.
I lived and rode 2 wheelers in So Cal for 20 years, and I know about rain grooves. Almost like a two wheeler, you have
to let it seek a little.
going into corners, or ramps, you need to weight the outside foot, and do a little weight transfer move to the inside of the turn,
Lots of folks, everyone? do this to counteract the centrifugal force that wants to throw your body wide. For me, just a "head and shoulders" kind of deal works just fine.
practice somewhere besides the freeway. It is a target rich environment, and you should be pretty comfortable before doing battle out there. Your 2 wheel safety instincts will help.
Assuming tire pressures and alignment are within spec, then it's a learning process. I came off two wheelers and the first highway rides felt really foreign and yes, unstable.
It may take you a couple of hundred miles to where you feel comfortable. I still ride both kinds and after a week on the bikes the Spyder takes a few miles to feel familiar again.
Exactly. I switch back and forth day to day. Once you get the feel, it is not hard to swap around, but more importantly, you learn the feel for the Spyder dynamics pretty fast if you follow the few simple techniques.
:welcome: and :congrats: on your new :spyder2:
The solutions are pretty much addressed above.
If not done already, read the Do's and Don'ts thread. It will cover many of the topics in detail. What you describe sounds a bit like over control and the possibility that the tire pressures are off. I would recommend checking them first. 18-20 in the fronts and 28 in the rear is a good place to start.
Check list
There is definitely a learning curve but check everything you can. My air pressures were off and lugnuts were not loose but they were not torqued properly. It won't be long before your knuckles go from white back to their natural color.
Oops - hit "Return" too soon.
Easy solution - dedicate a Saturday to a long extended ryde. Twisties, 4 lane highways, interstates, more twisties. You'll question your sanity the first 150 miles, be getting the hang of it for a bit, at 300 miles you'll decide you'll never go back.
I experienced the same scenario on my 150 mile ride home. The most important thing I learned was that the bike has power steering. When you try to control it like a bike, it feels very jittery. I've now nearly 8K miles since March.
Sent from my SAMSUNG-SM-G890A using Tapatalk
I had the same experience with speeds over 60 mph. Laser alignment made both of our RTs rock solid. No more panic mode when passing semi trucks!
:welcome:and :congrats: on your spyder. As stated in previous posts, coming from 2 wheels to a spyder, takes a little time. It took me about 350-400 miles. Enjoy and 1330club Dale
Welcome new rider,
Tire pressure can make all the deference in the world! more than I ever thought possible and it dosnt take much to make a change. another thing I would do is add the Baja Ron swaybar, I waited about 40,000 miles before I had it installed and it made a huge difference in cornering.
Tire Pressure
Checked the front tires and found they had 25 PSI in them. I lowered them to 20 and will see how that changes things. Thanks for all the help!
Welcome new rider,
Congratulations in getting your Can Am Spyder. I also got mine December 1, 2016. I have a 2016 F3-S Triple Black. I got a so so deal, but I realize I am very happy that I bought it though I should of got it in November. I was really nervous at first, and my I live in the Central Valley in California. I know the of feeling driving in the Orange County area.
I have read the Spyder Forums. I am plan to get the Baja Ron Swaybar, Laser alignment, Windshield, and the BRP idler kit. These are good recommendations from the people who ride the Spyder. Currently, I read the Do's and Don'ts and I am currently reading manual. This is my first motorcycle, and I am plan to get a motorcycle license so I can reduce my insurance.
All, I know is play with it, practice on it, and just have fun with it. ;)
Keep on ryding!!
I got our Spyder in August of this year. I had been riding a VTX 1800 2 up and alone. I admit my first test ride was a VERY different feel. We bought the Spyder and rode a couple of times 50-60 miles and pulled our camper. When asked by friends, I describe the ride like a snowmobile or a ski-doo.... very flat compared to my VTX. My dealer had told me to relax my grip and push rather than pull.... and we rode about 2000 miles to Arkansas and back the last part of October. We were on interstates, 2 up, pulling a Bunkhouse and while it feels different than my VTX, I felt comfortable and confident on our Spyder. Check everything as suggested and then relax and ryde!
Jim
2000 miles for me
I thought wat the crap have i done.
Then one day (it happened)
No more weaving, get a dring, change tunes, set cruise, all without thinking.
Natural doesn't come easy but when it comes you wi love it
I love R&R put another dime in the jukebox baby!
