First Oil Change for RT
Time for RT oil change. No lift, don't really want to ramp it up
Wild West Katy charges $200 for oil change on RT
Any other suggestions in the Houston TX area
1 hydraulic jack & 3 or 4 axle stands?? :dontknow:
Pretty easy to do an oil change, IF you can get down that low AND get back up again! :rolleyes:
$200 may not be too far out of reason. I don't remember what my first oil change cost me but it also included a safety check along with a filter. Don't forget to have them sign your owner's manual that indicated your first service was completed by a qualified tech.
Thornoli's
Place · Motorcycle Repair Shop
9306 Charterlawn Circle, Houston, TX
You should check him out. He works on Spyders. If you're on FB, look him up, or Google him.
Ask your dealer what is included in that service. Although you may want to do your own oil changes in the future this may be one time when you will want them to look it over. $200 for and oil change does not sound too bad but you can do it cheaper yourself.
I SpyderGoldwingOwner
For your first oil change, it is better to go to your dealer, it will validate your warranty
FlyBoy2121
