FIRST LIMP HOME TODAY
spyderryder53
Hi I got my first limp home today and pulled the code it says PO340 but I don`t see a match in the code search any ideas what it is
thanks in advance
Leon
Not sure what that code is, but anytime you get the limp home message, you could try the "key walk". Park the bike, turn it off and take the key out of the ignition and walk 50
feet away from the bike for a few minutes. Then try starting it again. Has worked for me a few times.
new speedometer cluster
I have a 2011 SR SE5 and we messed up the cluster when we changed the headlight. IT will start up and run , but the cluster doesn't work. So ordered a new one from the can-am company. put in new one and it will not start and shows limp home mode, and check engine light is on. But can leave old one in, start bike up and change out clusters and it works good, you can turn engine off and restart. but if you turn key switch off it won't start and you have limp home mode and check engine light again. Any ideas? Please help!
