Mazo EMS2
Thanks again to Finless Bob and his imagination. I searched the threads a bit to look for upgrades to hold the trunk open after some farkles had been added (luggage rack).....Turns out ya definitely do not need to spend $65 on another shock/strut to keep it open. All I did was add a coil spring to the strut shaft like Bob showed. Cost me a whopping $.99. Yup, not even a dollar to keep my trunk open. :bowdown::bowdown: to You Finless.
I discovered it isn't necessary to remove the strut all the way, just release the bottom clip from the peg and swing the lower end of the strut out. Then simply coil your spring onto the strut shaft while its extended. You may need to stretch your spring a bit, depending what you buy. Just make sure that it can be compressed fully so that the trunk closes properly.
https://youtu.be/AjhvfTHI4oY
