Looks like I'll need brake pads soon. Should I use BRP brakes or EBC. I can save money with EBC semi sintered pads. I had a dealer said they squeal. Also the windshield and fairing shake between 50 and about 65 mph. How can I determine if it's tire balance or drive belt?
????...number #6 was my post reference in the PM I sent you …..The tires are Kenda's. When I'm in the shake zone the windshield and instrument panel area shake but the tires and fenders don't look like they are bouncing around. The rear tire and my seat feel good. When I hit 70 75 it gets stable. Can you suggest any car brand tire that will work well? I'm running about 16 psi in the front and 28 in rear. Tire wear looks good. Where is most #6 ?
I purchased it at 4200 miles about 2 months ago. The problem was there and I knew it. The front two Kenda's were replaced at 3700 miles about March 2017. I also inherited a rough idle. Running Sea Foam thru it now. It idles about 1400 then bounces between 1200 and 1500 when it misses. It smooths out as soon as throttle is increased.
