PistonBlown
Having got myself a radar detector I couldn't work out where to mount it as I didn't want it on my bars, particularly as I'm sorting out a hand brake at the moment. I've also already got a RAM phone mount that's taking up a lot of space. Instructions said it had to be mounted somewhere level with a view to the front, it could be behind Perspex but nothing opaque.
Then I had a brainwave - I removed the screen, shade and safety card, then fixed a length of aluminum there instead that I slightly curved to match the lines of the panel. At the end I put a kink in it to give me the level mounting surface. I mounted this with counter sunk bolts through the grove normally used by the safety card which meant I could adjust it up and down if I didn't get the height quite right first time.
A bit of black paint on the bit's that may show, added the mounting plate, ran the cables and then put it all back together. Radar detector is out of the way of dials and as high as possible while still being protected by the screen and to my mind looks nice a neat + everything can be returned to normal easily if required.
