Filter covers
Nico75
Hi all does anyone know or has taken off the filter covers ? I know the air cleaner is on two clips so is easy to remove but can the cover for CVT filter be taken off Reason I want to spray both red to match side covers IF I can get paint code if not they will have to stay black! Best regards Nico 75
5 screws hold it on. 4 you can see and the 5th is on the bottom, little hard to get to (especially reinstalling).
Nico, with cover hanging down, I removed mine by sliding cover all the way to the left and gently pushing in left hinge and it came right off
I just went out and checked and you are totally right. Looks like you will need to remove the 5 screws I mentioned to get to the filter, but the cover comes off the way you describe. If someone finds a way to replace the filter without removing the screws please post because I'm going to start cleaning that filter pretty often. Thanks.
