FIAMM Horn question
Topshotta
Is it safe to install the FIAMM Freeway blaster low note Horn 72112 without a relay? My understanding is you only need the relay if you will be installing both the low note and high note at the same time.
As I see it..!!
you should be fine. If you add a horn using more current than the exsisting one add the relay. At worst you will blow a fuse. I have the dual air horns from bolo and did not add a relay and it's been working fine....:thumbup:
