I bought a used set of 1st gen Tricled fender lights for my '18 RTL (and a new wiring "harness" directly from Tricled). I have a few quick questions, please.
1) I don't have a jack. I watched a video of someone installing Ryker fender lights and they just unbolted the fender. The dealership mechanic said that's how he would install them, too (on my RT). Is there a way to install these withOUT taking a wheel off? I can buy a jack if I have to but I probably won't use it for anything other than this. I don't have a garage/carport so no truely flat surface so stability is also a (minor) concern.
2) If I have to remove a wheel, what's the best jacking point on either side? If possible, I'd rather only get 1 tire off the ground at a time as my parking area is slightly sloped. (My house used to be a small commercial office so instead of a traditional driveway, I have a fairly large concrete parking area. Actually works out pretty nicely, for the most part.)
3) Since these are used, the double sided tape needs to be replaced. I know 3M makes something "automotive" that's made for this but I'm not 100% sure what to search for.
Thanks, all.
Thanks, all.
