Federal Front Tires
36,000 plus miles on my 2015 SM6, and they still measure 5 to 6mm on tire gauge, with even wear across the tread. 16 to 18 psi.
I have the Federal Formoza tires. The po put them on it. I don't know how many miles they have on them, but they have lots of tread left. My only complaint about them is noise. They whine terribly! Any suggestions that might help the whine? I am running what the manual says for pressure, 18 lbs.
I have them on my 2018 F3L and mine do not whine. I put in 18 lbs also. Wonder if your alignment is off.
Another thing came to me. Are your tires mounted correctly. There is an inside and outside stamped on the tire. Look at the sidewall an see if it says outside on both. If not I would have them remounted and balanced.
I will check for the inside and outside. I am pleased with how it handles, just wish the noise would go away. They are worse than the Dunlops used to be.
