Fault Codes
Storey
I have a 2017 Spyder RT Ltd. Presently showing 3 codes I can't define...could someone help me please. They are: C0031, C0063, C0034, Brake Failure.
Thanks you
Welcome, welcome 👍
From the codes given you have problems with the speed sensors on the front wheels C0023, C0034 and the YAW rate sensor. If you get the spydercodes app you will see the codes and suggestions. Check those sensors for GAP clearance and toothed disc. Have you done any work on the wheels, brakes or lighting around that area that may have bumped those sensors..? :thumbup:
I had done an oil change, had the bike jacked up, don't believe I hit anything but will check. Thank you for your help.
I tried to download the free Spyder Codes on App Store, Play Store and Amazon...the provider told me its no longer available...does anyone wish to share their Spyder
Codes? I do have what Lamonster shared just not the Spydercodes from Apps.
Cheers
So I am guessing the short drive did not work? All 3 of those codes relate to sensors connected directly to the VCM. Sometimes call it the ABS module, but it does more than ABS. Maybe you bumped the harness connector for it. During the oil change. Inspect it.
Everything has worked out. Your advise to take it for short ride cleared all fault codes. Thank you so much!
Cheers
