Fault code reset - any way to do without dealer?
Marshall
VSS fault code, limp mode only, looked around, found a speed sensor wire rubbing against the tire.
Need to clear fault codes, anyway to do this without going to the dealer?
And while I’m at it is there anyway to actually see what fault code is on?
Thank you.
first of all we need info such as what model and year Spyder that you have.
different models and years have different ways to pull up the codes.
sometime you can just unhook your battery for a few minutes and the computer will reset and the code will not show, even though it will remain in memory
Cruzr Joe
