OK I will be serious. 3 things I would do, exhaust, air filter, and PowercommanderV with Autotune. I have done more but this was the best bang for the buck. I had the Juice Box Pro but does not compare to PowercommanderV. If you do this get with me and I will give you my map to try. There will be as many opinions as there are members so do your research and pick and choose. You could always go turbo like others...............maybe me some day.....................ray:
The Dynojet Powercommander also comes with an o2 mod. The powercommander takes care of the open loop portion of the fuel curve and the o2 mod takes care of the closed loop portion, both can be custom maped but in different ways. The Autotune will make the open loop exactly how you want it no matter what you change or the conditions. The o2 mod is set at 13.6:1 and can be changed by percentage up or down. The bottom line is it makes the power curve so liquid smooth it feels like you have gained more than you really do but you will gain. The honest truth is you will spend a lot for a little as mentioned before but some of us can`t help our selves.is there a difference between green filter and k&n filter? also is o2 mod same as powercommander?
Also get rid of the air box and get the KewlMetal Performance air filter kit, Bajron spark wires, spark plugs, vent filter, and oil filter kit (to change over to Amsoil). You can find all these vendors on this web site. Next take off the windshield, sit low, and twist the throttle. That's IMHO.
Mike
