Nils888
Hi All
I was having a Farkle session today. I am installing a Baja Ron sway bar. And waiting for a set of Elka shocks to get here.
While pulling of the belly pans I noticed a some oil on the right side rear belly pan. I thought it might have been the recall
oil plug leaking. So I started removing panels. When I got enough of the panels removed to see the plug. It was not where
the oil was coming from. With a little more looking I found that the clutch cover oil drain plug was the leaker.
With that being figured out I will just change the oil early and replace the drain plug gasket. I have 1000 miles on the Spyder.
So I decided to remove more panels and take a look at the rest of the trike. I guess I got a little carried away!!!:yes:
It is a busy thing under the plastic!!! So while it is apart I gave is a good cleaning and waxed all the panels.
And I installed the sway bar and links. Very easy install thanks Ron.
