Farkle surgery
Was raining buckets all day yesterday, so I finally made the attempt to put in the 12v outlet.... What a pain!!!! Just about had to pull all of the yellow Tupperware off of the front end except for the rad & oil cooler shrouds, I'm hoping the side bags won't be that hard to install... image.jpg
Depends..!
On the 2012 RS the wiring for the power outlet is all there with the boot. Only had to remove one left side panel. Now where you put the plug may make it more difficult. Mine is in the frunk so one hole drilled through hooked it up and done. Now for the side bags, can't say..found if I go through the instructions a couple of times first things go better even though I'm one of those "who needs any :cus: instructions" type of guys..!! Good luck..!! :thumbup:
