Fans running a lot??
Lew L
Well-known member
So here we are, 200 miles from home, at a biker rally in Winnemucca, Nv.
And the fans run a lot.. Checked the coolant level and added maybe 2 cups of water. Didn't Help.
Any thoughts???
Checked that also and they are clear. Momorn Crickets are out in droves but a good inspection of the screens and radiator show clear. A bad relay or sensor perhaps??
The fans are not constantly on but more than in the past. I'm puzzled.
The Spyder ran fine and showed NO signs of overheating.
We both have 2014 RT's .... did you check both sides of the radiators ???? ... also is the CAP tight and secure ???.... Mike :thumbup:
Yes and yes. Even checked the oil level properly and as always--- it's where it was 3,500 miles ago
Maybe I'm just being a worry wart but the:spyder2: has been so good ( Perfect) for years this fan situation had me concerned.
Thanks for nor responses.
Lew L
How about the ambient temp? It has been extremely hot here so early in the season and my temp gauge reads just a bit higher than it has thus far this year and my fans have come on a bit more frequently but not excessively so given the slightly higher temp gauge reading. I too checked the cold coolant level and it was right on the cold line.
Ambient temps in low to mid 80s . Took the :spyder2: out later after checking everything and all seemed fine. I just don't know.
You may want to poke around the water pump and see if you have any signs of fluid dripping out the weep hole, just for kicks!! Good luck
Cap tightening worked for us when Linda's heated up at the Grove OK Rally in Oct 2019. Ann and Joe helped take care of that one. :bowdown:
It could happen to have the fans running like that with the temps in the 80's. If it wasn't over heating I wouldn't worry to much about but just keep a eye on it.
Mine turn on while I am riding at times too. More so in slow traffic too.
OK, thanks triker . Now for the Ryde home from the Run-a-Mucca rally in Winnamucca Nv. About 200 miles. Leaving early!!
Where is the temp sensor for the fan located??? More for future reference.
Thanks in advance,
Lew L
I am thinking its attached to the fan housing, but I am not sure!!!:dontknow: That's where I have found them before on cars!!
Coolant Temperature sensor is on the left side of the engine. Looks like somewhere around the middle of the engine from the picture.
If you have BUDS you can check that to your gauge too and if they match the sensor is probably good.
There is a OHM test of the sensor too.
Seriously overheated ( by the temp gage) over in the Gold Country of Cal. Hi temps, fluctuating gauge , fans running alot. Added some water ( not much though). Long tow home ( thank goodness for AAA Premium)
No smoke or steam, no leaks visible, no loss of power.
Going into the shop:(:(:(
Not soon......... The shop I kinda trust is out 7 weeks for service. Vacation to Pikes Peak and three-wheel rally cancelled!! Oregon ryde with friends cancelled. V-Max is a great back up but not for cross country with my wife.
After a 30 mile ride on the highway yesterday, my 5 day old Spyder F3 had the fan running as the rig was idling outside my garage. Outside temperature was 12 C (about 55 F), so outside heat not an issue. I assume this is a normal occurrence.
Rick
