factory CB
davehirst
I have a 2015 RT Special Series with a Factory CB. I can hear fine, it's just when I transmit, others say it is scratchy and hard to understand. I have tried several headhsets with the same results. I could ck the SWR but don't know where the unit is. How do you find the CB where the antenna connects to it? Other suggestions.
CB Location
The CB itself is mounted just in front of the right saddle bag (as you are sitting on the bike). So, you have to take that long side panel off ... well, basically the whole right side to get to the unit). The antenna cable connects there and is then routed around to the left side for connection to the antenna itself.
Another thing you might consider is the state of your plug wires (BRP uses some that are notorious for causing noise, especially after that are messed with in any way, like replacing the plugs). I know on my 2012 RT, I had the plugs replaced and neglected to replace the wires at the same time .... I could still hear okay but all my transmits were filled with static. Replaced the wires with a set from BajaRon and it all cleared up.
Good luck finding and fixing the problem .... Ann
