F3S Turn Signal Indictor
Dray
I would like to mount two led turn indicators on the dash that would catch my eye
and say O.K., turn me off. To that end I chased down the wiring for the turns signals
and I am ready to do this. But my little brain ask how this would affect the factory
OEM indicator or a better question is would the OEM indicator keep all 3 indicators
flashing. I have tried chasing down the indicator wiring diagram without much luck. I tend to
think that there has to be some diodes somewhere in the harness to keep the OEM
signals straightened out.
Anyone with experience in this is welcome to jump in here and pass on your knowledge.
It would be much appreciated!!
Dray :yes::banghead::yes::banghead:
Well....
I put LED green singles at each side of the dash to tell me the blinkers were on and which side. I simply tapped into the turn signal wires at each one. Right and left. If they are LED's keep the polarity straight and test before closing things up. As long as you maintain the stock bulbs in the turnsignals all will be good...:thumbup:
The left and right turn signals are powered and controlled directly from the gage cluster. Adding a couple of leds to each side will have likely no effect. If the extra current draw happens to cause hyper flash. There is a procedure to recalibrate it.
F3S turn signal
Thanks Guys, just exactly what I needed to know.
I would be lost without this forum and all the
knowledge it has. Thanks Again
Dray:yes::bowdown::yes::bowdown:
