F3 Top Case
E Reed
Just added the top case added to my 2016 F3 Ltd however, the nanny flashes an open rear case warning off and on. Any suggestions to a possible resolution would be greatly appreciated.
Eddirt
Eddirt
It's the latch on the case. Mine did the same thing. It's not making enough contact to push the sensor down. We added a piece of thick foam tape to the part that sticks down to contact the switch. Works great. :thumbup: Tom :spyder:
Let's see....
It's all in the switch...:agree: don't know the type of switch and if it has any adjustments or tabs that can be bent a bit for better contact . :dontknow:
Mine did the same thing. The latch is only being held in place with clips. Put a screw in it and it work flawlessly. But definitely a design flaw.
Top case micro switch
The micro switch for the top case is only held in place with two plastic fingers on the sides and a plastic stop on the bottom.
There is a hole in the micro switch for a screw or maybe a plastic push pin to hold the switch in a non moving position. It looks like no one got that screw or pin.
T.P.
Thanks to all for the replies about the top case warning issue, did the foam trick for now and it worked planning to look at the latch mods later.
Eddirt
Another latch issue lol. Seems like anything that opens or closes on these never seems to be quite right :banghead:
I remember the demo in our local dealer. Neither rear bag on the T would even close. Adjustments go a long way.
