F3 TL Steering
NewHornist
I had a 2014 RT-S that I sold because the steering was too heavy for me since I have problems with my shoulders. I added a Bajaron anti sway bar and that helped but not enough for me to be comfortable. I am thinking about getting an F3 Limited but I'd like to know what you all think about the steering. I have heard that there isn't any change from the RT except that the seating position is significantly different. Is it different enough to make the steering easier?
I went from the ST to the F3 Limited. I realize there will be differences between the ST and the RT but the F3 rides like it is on rails compared to the ST.
I would test drive an F3 and see but you may not notice until you get into some real twisties. Upgraded swaybar and shocks will always help.
I was told by Len at Pit Bull Powersports last week that the 2017 F3-t's have a new steering. check that out T.P.
Curious. ....
Heavy steering can come from several places. Supposing the DPS was working properly your next most common reason is tire pressure and tire. I run 17 lbs but have an RS. The RT should run higher 20 lbs give or take. The higher the lighter the steering...:thumbup:
Also, if the steering axis indicator is off, it can be a real fight to steer. And, unless it has had a laser alignment, it is probably off. The non laser alignment at the dealer is a joke.
I went from an RT to an F3. The F3 allows for the handle bars to be adjusted to a more comfortable position and that makes a difference in the steering.
Yes! I was able to test ride a 2015 F3-S (which I purchased today) and it is much better than my RT. No pain running thru my shoulders and upper back. Yay!
I did get the laser alignment for my RT. I didn't really notice much difference after but the guy that did it said it wasn't out by very much. The biggest improvement was adding the BajaRon anti sway bar.
I just bought a 2015 F3-S. I will get the sway bar. I don't know what shocks come on the 2015. What do you recommend?
The 'short reach' pull back bars on the F3 make the steering stupid-easy.
Thanks for the info! I gather these bars are closer to you than the stock bars? Is there any way to determine which set of bars is best for a specific rider? I'm 5'6" and short waisted so it seems like the short reach bars would be a good fit for me but I don't really want to buy them and get them installed and find out they're not.
Get
on your bike and close your eyes. Now place your hands where you want the grips to be and would be comfortable. Hold still and open your eyes. If they are 2 or 2.5 inches closer to you than the stock grips and up or down just a bit, the short reach bars will get you there.
If you reach out while your eyes are closed and the current grips fall where you do, you are already there. Your stock grips can be adjusted up or down a bit.
They're not very expensive.... like $130 and install in about 30 minutes. You can also angle them down quite a bit to bring them even closer to you. Just make sure they don't hit the tank when fully turned. I love mine.
