Bruiser37
All Bluetooth systems support only one registered connection at a time sooo you have to decide at any one time which bluetooth devise you want to use... no multiple connections. I just installed GarminZumo 660 complete motorcycle kit with everything you need for F3 T Amazon new $340 , forget all bluetooth stuff and very expensive BRP GPS mount & cable. Use RAM GPS motorcycle mount kit that comes with 660, tap & connect well marked user switched accessory power cable under left panel. Drill a small diameter hole in top center compartment that houses short OEM male MP3 cable... pass female MP3 cable from GPS mount into compartment & plug in MP3 connection. Load 660 SD card with tons (hours) of your favorite music, set radio to AUX, turn up volume (not too much, it has auto volume control) and enjoy your music that pauses for voice direction commands from trip routes. Voice command & music fidelity is outstanding and the music is yours... no commercials. How simple can you get. This set up will work exactly same for the very expensive Zumo 590 & BRP center mount kit which I don't recommend.
