After just installing my FOBO system and using my LaMonster Air Pump for the first time, my air pressure on the front tires (cold) is 17.2 per the FOBO's after setting the air pump to 18.0. Is it normal for the two readings to be that different? (Perhaps I didn't remove the air pump from the tire quickly enough?)
Also, my FOBO reading on the rear tire is 29.2. My target for the rear is 30, so I didn't bother to apply the air pump to it.
So, I'm curious what air pressures you guys run your tires at? I have a 2016 F3-T with stock tires, and I weigh 220 lbs if that matters. And I never ride two up.
Also, on a totally unrelated note - Can you guys actually fit your helmet into the frunk? Granted, I have a large head so maybe that's my problem, but there seems to be no way of fitting my 4XL HJC IS-Max II into the frunk. BRP states that the frunk should hold your helmet. Does it fit yours?
And finally, also frunk-related - how do you remove the frunk insert on an F3-T to get to the battery? I know that the dealer showed me, but I guess that I suffered from "information overload" while she was doing it. :dontknow:
I've only had the F3-T for six weeks so things are still new to me.......
Thanks!
Thanks!
