F3-T Front Turn Signal Conversion Kit
NICE!!!!!!:clap:
What about the F3 and F3-S????
I would love to convert my turn signals to running and Turn function.
NICE!!!!!!:clap:
We are working on a kit for the F3 and F3S. TnCharlie has a set on his. We swap the sockets out, add a second filament and use an LED bulb. White running light and amber turn signal. We should have those ready by the New Year.
Will these work if you already have Lamont's amber LED strip that taps via connector into the existing turn signals and wraps around the mirror assembly
Thanks, Rick?
Thanks, Rick?
Hi Rick. Yes, they will play together just fine. You will need to make sure the Lamonster LEDs are attached to the input wires and not the output wires. You will unplug the light at the 2 pin connector. The pigtail that goes to the light would be the output side, so connect to the other wires.
The Lamont LED's came with their own connector. Disconnect turn signal connector, plug new LED connector in, plug turn signal connector into the LED connector. So would your connector tie into to this setup?
Rick
Rick
Yes. Plug in our connector as the last one.
