F3-T Brake Running light wiring
No 2817
I wanted to add the Rear front fender led lights. I need to know what wires under the seat to attach to for running and brake and of course the ground wire. I got every thing wired up, up to under the seat but not sure what to connect the three wires to on the Spyder. Red = Brake, Blue = Running, Black = Ground
Anyone done this on '16 F3-T?
Thanks,
Chris
Thanks,
Chris
Are you talking making the front fender, red reflector, a running/brake light? If so, I can't help you. If you're talking about getting power for the red and amber front fender lights, you just tie them into the white, front fender marker light.
Although, TricLED is coming out with a plug-n-play adapter for the rear tail lights for the F3T/L (Not sure when but I understand it's being manufactured now.). I would assume you could tie into that to make the front fender red light a running/brake light.
red reflector
Yes the red reflector. I have the white light and amber side lights installed and working fine. Have the red reflector leds installed and wired up to the rear of bike. I need the color codes for wires for brake and running.
Chris
