F3 seat removal
Yes . . . .
. . . . it is in the manual. The passenger's seat is released from/by the ignition switch- then you will see the two bolts securing the drivers portion.
Tom
Pop the rear seat off using the key and then there are two hex head bolts (10mm) you have to take loose.
Rear seat in place (never removed) doesn't seem like it's attached well on one side.
From the back, left side lifts up with only a little pressure with one finger. (Appears to be only locked in place on the right side.)
Thinking something must not be right.
