F3 se6 shiftiing
Doug
What is the rpm that you shift at, thru all the gears and at what rpm do you cruise at while driving the speed limit. Have looked at the dos and do nots, by that scenario, I would be in forth or fifth gear driving around town, 50 km zone.
No F3 here, but have the 1330 engine. For smooth, quiet shifts, 3000 to 3500 rpm seems to be good. 50 km (about 35 mph here) would be third or fourth gear. I try to keep the tach spinning at about 2500 to 3000 rpm. 50mph (about 90 kmh) is where I would be riding in 6th gear.
There is plenty of low end torque, so you will not be lugging the engine at 2500 rpm.
when you want
The previously stated 3000-3500 is a good rule of thumb. The 1330 engine seems to be pretty forgiving so you can shift at other points. It won't let you shift too early, and there's a throttle governor at the high end so you can't rap it out.
coming from the rs i want to run it to 5k before shifting, but have learned very quickly that you don't need to.:thumbup:
I want proof that you own an F3, I think you still have that snazzy RS....:D
waiting for my graphics guy to do his thing, then i'll show ya that we have one! someone want to vouch for me for the time being???:roflblack::roflblack::roflblack:
arrow
On the mid gauge right where the gear position appears an up arrow will show up as you accelerate and will disappear as you shift, can't find purpose of this arrow in manual
Shift rpm depends on your desired rate of acceleration. (not your speed) This engine has enough low-end tq to shift at 3K if you are accelerating easily, but if you want it's best motivation, I'd shift at 6-7K rpm. Once the engine is warmed up (oil temp, not water temp), you can't hurt it with those rpm.
Heck i'll vouch for him.
It's called the phanom F3 lol :roflblack::roflblack:
Not true till you have pictures!!
