Yeah. I see 2 shoulds. What I see is a person debating on how to get the bike out of the "line of fire"
If they aren't familiar enough with their ride to get it in neutral, my solution would work.
The thing is
Hoginedgewood, if it's an
SE then the moment the motor stops & oil pressure drops, then even if it
IS jammed in a gear, due to the lack of oil pressure holding it engaged, the clutch still disengages the engine from the gearbox, belt, & drive sprockets, so it'll roll away if you don't use the Park Brake. :shocked: And if it's an
SM, then even if it
IS jammed in a gear, pulling the clutch lever in will disengage the engine from the gearbox, belt, & drive sprockets so it'll roll anywhere you like, unless/until you release the clutch lever.
Just like
dorourke apparently did in his first post in this thread,
many get caught out by this, thinking that just cos the dash shows it's still in a gear it won't roll! :cus: However, just cos the Gear Position Sensor still says the
GEARBOX is in a gear (any gear)
if the engine isn't running in an
SE, then (barring any other mechanical failures
) the clutch isn't connecting the engine &/or gearbox to the rest of the driveline, so the Park Brake is
ESSENTIAL to stop it rolling! And with an
SM the clutch lever does the same thing - so in both the instances
ottawa-rider suggested in post #4 &
Snoking mentioned/you quoted, pulling the belt off any sprocket would be
completely redundant - the Spyder will
still roll with the belt on!! :thumbup:
Now if the clutch mechanism had failed & jammed the gearbox in a gear with the clutch also jammed & inoperably still engaging the rest of driveline to the gearbox & belt, then
that'd be where your '
remove the belt' scenario would come into play!
hyea:
Make sense?! :dontknow:
