Up to 2012 we had an adjustable spring tension shock fitted to our Spyders then in 2013 they built the ST and to cut costs BRP opted out of that successful option by fitting a cheaper shock and spring with non adjustable spring tension for when one has a pillion WHY. Then because know one complained they decided to carry on with a much cheaper version as the part number’s don’t match to there best model Spyder to date the F3 series, they have a bigger fuel tank and the rider sits farther back all putting more weight over the rear suspension plus non adjustable WHY.
Now what I’m trying to say to you all is the main fault with the cracking of the welds is caused by the shock bottoming out so BRP are trying to cover up there stuff up by fitting a strengthing plate on top and hope the problem will go away and every one will go out and buy another shock that is adjustable.
Well wake up every one BRP know they have a big problem that’s why they have now at least are trying to half pie fix it with the 2016 series Spyders with a heaver spring and trying to con everyone to spend more money and buy one for there 2015.
NOTE this fix should be at no cost to 2015 F3 owners this fix should come from no other than BRP they sold us a 2015 Spyder that had 2 seats hand grips for a pillion and a back rest you could purchase all so you could ride 2 up at any time but sadly NO AJUSTABLE REAR SHOCK, this is a total back would step all to save them BRP money.
