F3 rear brake strobe light
johnv50
I remember seeing a plug and play harness that causes the gtrunk brake lights to flash in a set sequence
but I cannot seem to find it now. A link I had was to Spyderpops however that links comes up with an error.
Help !!!
john v
I received replies from both Custom Dynamics and TricLED re: F3 brake strobes. Here are their replies :(
1.) TricLED:
Hi Jeff, at this we do not because the turn signal is tied into the brake line. The F3 is the only one that shares this output so it can’t be done at this time. We’re looking into possibly a different part of this harness to maybe grab that signal so stay tuned.
Thank you for your inquiry
Best regards,
Reggy
2.) Custom Dynamics:
Good Morning, Jeff!
Thank you for considering Custom Dynamics for your 2019 Can Am F3-S! Unfortunately we're unable to offer a Magic Strobes brake light flasher for your particular model due to the parameters of the vehicle's electrical system and the way the rear lighting is wired. There are both high and low load thresholds on your bike which make adding/changing lighting or incorporating modules more complex.
While we unfortunately can't offer the particular product you had in mind, please don't hesitate to let me know if you have any additional questions and/or if there's anything else I might be able to help you with in the future! Thank you again for considering Custom Dynamics! Have a wonderful week!
Thank You, Erin
The decel light will work from smart turn. Also, this from Spyderpops .. https://spyderpops.com/f3-f3s-rear-...ll-not-fit-f3t-f3-limited-or-daytona-edition/
I have Spyder Pops Top box light that has the strips that go around the top box and down from the turn signals. they have the brake strobe built in along with running lights, and signals. all plug and play but running the small wire threw the side boxes is a bit if a trick.
I have the brake strobe in mine. It is a 2017 F3 LTD Spyder pops will work on you 2017 F3 LTD.
I added a separate strobe to the license plate holder. Works great. VERY bright. It causes cars behind me to give lots of space 'tween them and me. In the video, I have the three LED light unit behind blue tape because it's so bright, you can't see anything else. Info at the link in my signature.
john v,
SPYDERPOPS.com is the correct address.
I have the spyderpops part # SPY 182 BRT
Good luck!
Rotax
