Carl, you are talking about the F3 Limited.
Unfortunately, I doubt either of the two stock F3-L OEM shields will work for your height. The wind will hit you right at chest height with a bad case of bobble head. You will have to buy aftermarket. I have an F4 25" which works a treat at keeping the wind at the top of my helmet.
I don't believe the RT sway bar works on the F3-L, but check with Ron.
Make sure you give the dealer plenty of notice for your test ride, and INSIST that he has the Position 5 foot setup for you. I found the middle of the road handlebars worked best for me (I.e neither long reach or short reach).
I'm not sure how heavy you are, but the F3-L comes with the 2up shock, so you can disregard the earliest post re needing to buy the 2 up shock. I only upgraded mine to Wilbers because I am over 310lbs and exceed the max allowance when riding 2up. The stock shock was handling it well, but.......
You can see the options I am using, in my signature.
