F3 Owner Opinion
GaryTheBadger
This is my unsolicited opinion of the 2015 F3 SE6 after 3000 miles, in comparison to the 2008 GS SE5 that I owned for three years, plus dozens of customer Spyders that I’ve worked on for five years.
The purpose is to help others who are considering an F3.
Overall I am extremely happy with my F3 and would, without hesitation, recommend it to a first-time Spyder owner or as an upgrade from a GS/RS. BRP got nearly everything right this time!
PROS
Reliability
Comfort, adjustable pegs and bars, upright seating, built-in mini-backrest
Consistent drivetrain performance
More HP and torque
Added sixth gear
Better brakes
Very stable engine temperature
Less heat from radiators onto lower legs
Increased maintenance interval
Improved fuel mileage
Optional fuel economy mode
No wrist or back pain (this made me give up my GS due to its sport-bike posture)
Fuel tank can be filled from either side
Can add BRP cruise control to base F3 for about $200 and two hours
No hard engine re-starting due to heat-soak
CONS
Loss of 40% front trunk space compared to other models
Driveline vibration at highway speeds (Will BFR fix?)
Non-adjustable, too-soft rear shock (Will BRP fix?)
Passenger foot pegs will not stay in up position (Will BRP fix?)
Handlebar controls hit and mar the body panels at full-lock
Low chin, hits speed bumps and driveway entries
Dim instrument panel turn signal indicator (Fixed! See here: http://www.spyderlovers.com/forums/...sory-LED-Turn-Signal-Repeaters&highlight=muth)
Black fenders on non-black F3 (Fixed with color-matched fenders)
Still using incandescent bulbs on a modern $22k+ vehicle!
High BRP accessory cost, some are poor quality
Limited body color choices
Extensive oil level checking process
Some handlebar switches not backlit, a safety issue
Ambient temp display always reads too high
If laser alignment is necessary, why isn't it done at the factory?
Factory wind protection options inadequate
Agree
Especially on the headlights and the non-backlit controls. Don't get why either of these decisions were made - would add marginal cost to the bike.
Otherwise, I think it's a great machine as a first tymer.
Nice review...
great observations. Glad your enjoying your new ryde. :2thumbs: you make a great salesman for the F3 but there is just something special about the RS for me .:thumbup:
Seems perfect timing for your review. :clap:I had an F3 demo unit as a loaner while my 09 phantom was being "repaired " at local dealership. I won't get into details as to what my 09 needed but I will say that I was blown away by the F3.
I have to admit, I was lukewarm to the styling when the F3 was introduced and never would have considered buying one. That is until I actually had one for 5 days. I totally agree with your assessments of the bike. Comfort, power and fun-factor are off the charts imho.
Now only item holding me back is the cost of purchase. Not that I'm saying price is totally out of line but a $25k cad :yikes:, toy is not going to pass the spouse test at the moment.:rolleyes:
My 09 is still my baby and couldn't part with it just yet.
Oil CheckI came off a Yamaha
I came off a Yamaha Raider had dry sump system basically the same, ride 5 mi stop let idle 30 sec then shut down & check, I usually tried to remember to do it after a ride but most times forgot, only did the 5 mi thing after an oil change.
Very Objective !
Thank you for a clear, unbiased review. For those on the fence, this will help them to make the right decision for them. I enjoyed it and learned much. Two thumbs up.
You don't have to buy the more expensive models- I got the Base F3 sm6 for $18,000 and taxes.
I like how they have made many things easier like checking oil, brake fluids, changing the oil filter without laying on the ground with a torque wrench in your hand and changing the rear bulbs is as hard as taking off the rear seat, No Greasing bushings and No valve adjustments and hopefully a engine that will perform for years.
That being said my GS was in Great condition when I traded it in with 33,000 miles BUT at 66 I was tired of the crouch rocket position and feeling like I was going to get tossed in a hard corner even with Elka's and the Ron Bar?
The Only Slight Negative to me is that Manually shifting with your feet out in front of You is Not as smooth as Manually shifting my 2012 RT with your feet below you. Downshifting (To Me) is Not as smooth with the lever out in front But upshifting is No different. If your concerned you Might want to consider a SE6 Auto Tranny?
Have over 1,000 Miles.:yes:
I came from two-wheelers so do not have the personal knowledge for comparison to other Spyders. That said I love the frunk, it is the largest I have ever had. I do not have problems with my handlebars hitting or passenger foot pegs not staying up. My single biggest complaint is the amount of rain we have had since I got mine.
Thank you for the write up. It's good to see what people think about the model after they have had a chance to put some miles on it. :yes:
Excellent Summary
Gary, the only other Cons I would consider:
Windshield/wind protection
Ease of mounting & dis-mount​
I personally don't have a problem with any of these, but other Spyder riders and new-to-Spyders-riders may have.
Thanks for summary
As a newbie soon to become a F3-S owner, it was good to read your summary because you have experienced just over 2000 miles of this beauty. Blueridge windshield and heated grips are at the top of my options list and by the looks of things the UK dealers have these readily available in stock and if they haven't they are saying around a week to get hold of these options.
Thanks for your summary on F3.;)
OBSERVATIONS
GOOD OBSERVATIONS......
however, i disagree with the statement you made:
"Loss of 40% trunk space"....
you knew, as i and others, what the
F3 was prior to purchasing it... if the 40% reduction in storage space was such an issue, you wouldn't have bought this particular item...
YES, i miss the storage i had in my '09 RS, but i knew i would when i first looked at the F3....
all-in-all, i'm 100% satisfied with the F3-S, and that's after riding it for 16,000+ miles of smiles since March 1st of this year...
Dan P
SPYD3R F3-S
I've wanted a Spyder since I first saw them back in '09. I had a Mom who was a nurse and wouldn't even let me look at a motorcycle!!:banghead: Finally talked the wife into letting me get an F3-S this year and I LOVE it!! I love the stability of the reverse trike format and I love the comfortable riding position. I have noticed some really good deals on the F3 right now. I picked one up about 3 weeks ago for $18k out the door. I am glad there is an option out there for those of us who want to ride but are too afraid to learn to ride two wheels......or have a spouse that would NEVER let us learn to ride a two wheeler!! Thanks for the review!!
Nice write up by the OP and I respect the opinions and appreciate the candor.
I'd like to share my opinions of my F3.
PROS
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Cons
None
None
None
None
None
None
None
None
None
None
Not trying to be a wise guy. Just being perfectly honest. nojoke
DITTO
PROS
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Fun!
Cons
None
None
None
None
None
None
None
None
None
None
DITTO....
Ahh. . . I see your problem.
"Loss of 40% trunk space".... \
It is NOT a trunk, it is a glove compartment. Still, that is about 60 times more storage space than other motorcycles have.
It is a shock for people who have owned any of the previous models of Spyders. But, if you are like me and love the F3, you will hardly notice it, if at all. Isn't love grand?
Oh marcojolo you make me so JEALOUS - $18K out the door??? Well Done and Enjoy! Here in Oz it's $29K out the door, and given our aud is 75c of the usd at the moment (on a good day) you can do the math... AND I think we earn about the same (tho no analysis done so could be wrong here...) I am so JEALOUS. I had an RS, now have an ST, husband has an F3S (loves it) and I just sat on an F3 with U-Fit system for the first time and am SOOOO tempted by the F3-T (which we may see by mid 2016) --- but here in Oz I'll bet they only bring the Limited in in the SE6 format (I so hope I'm wrong) which at Usd27K translates to .. what's your guess? If USD18K = AUD29k ... hmm. I have a feeling I'll be riding my ST for a few more years yet! If you can figure out that so-ungrammatical sentence you can claim an Award...
I think one of the reasons I got such a good deal was because I have been lurking on this site for 6 months or so and everybody kept saying to wait until September and there would be great deals to be had.......and I'll be damned if they weren't right!!:yes::yes:. I basically got on cycle trader and Ebay and found the best deal I could knowing that I would have to drive somewhere to pick it up......which I was perfectly fine with. If I had any riding experience I would've drove it home........Maybe on my next spyder purchase I can do that. I have dealers around where I live that I can get it serviced at. I feel bad for you guys in Oz.......it seems like everything is more expensive there. I play guitar as well and I notice that in Oz that the really nice guitar that I can get here for $1000usd costs about $2000aud......I don't get why that is but I know if frustrates the hell out of the Aussie guitar players that I know from various message boards!! I really thought about waiting to see if BRP did anything cool to the F3 line before buying but I figured if they did it would just cost me more money and I can always upgrade down the road. The only thing I really want right now is some corbin bags......I figure I get some for $2k and I am still $4k ahead.........:yes::yes:.
Yep we in Oz pay more ... and govt wants to slap 10% tax on everything bought on-line (currently 10% on everything over AUD 1000 which includes tax on the shipping too!). Oh well, we deal with it.
I'm thinking maybe F3 with Corbin bags as an alternative to F3T which I suspect will be way expensive here... but we also have horrid rear indicators on alien-looking stems, which can't work with the Corbins. My thinking cap is on re 'flush mounted' indicators on the bags.
It's always a lot of fun! Love to read everyone's reviews, thanks all.
