.Just wanted to show y'all my new kitchen living room and bedroom, which are now in the aft quarters of the F3. Bathroom remains in the Bow. Open lid , one leg over, have a seat. You get the idea......I was only allowed to post 5 pictures, but since the basic set-up is identical, i.e. use of the givi wingrack etc, its realy not necessary. I just wanted to thank the guy before me who figured the basics out. I believe I used other holes in the rack then some of the other mods, because I had to fiddle my way around the signal lights, where there is no modification possible due to german R's and R's. Generally I used hex M8 x various lenghts, the brackets I had laying around. They have a 6mm slot, which I opened at the appropriate spots with a Dremel to 8mm. For the topcase, I used 3mmx25mmx500mm Aluminum stock, plenty stiff. Again only M8 was used. AND YES, I DID PUT A RADIUS AT THE END.The angle of the bracket brings the topcase-plate above the taillights, and has only 30 mm
overhang beyond the max lenght of the vehicule, which is the licence plate light.
I ride mostly 2 up, and the seat position was also not impacted. Everybody is happy.
Regards from beerland, Pete
